Hi folks. Got to go to this end of next week, customer says door locks,door locked light flashing, nothing else. Any info on accessing test procedure/fault codes appreciated. Got the 1120,1140 fault codes off the site,may be the same. Thanks. 🙂
Re: Zan ZWG 6165 PNC 91490456001 Test procedure Tech info
Rograbbit wrote:Got the 1120,1140 fault codes off the site,may be the same.
I’ve no idea what you mean by 1120, 1140. 🙁
Error codes are established by the flashing of the Start/Stop LED. Count the red flashes and then the green. Count the red for the first digit of the code, the green for the second.
Sorry the 1120, 1140 are model numbers listed in the fault code guide and their associated faults. As the 1120 and 1140 are of the new generation (chinese), didnt know if they shared the codes. Still dont know how to access codes on the new machines. E-mail roger-sly@btconnect.com 😀
I don’t believe this is a Chinese made machine. Check your inbox or junk mailbox as I have sent you two seperate emails with some good reading attached….enjoy! 😀
