zan1415w wont start
  • #20432
    delta01
    going to it tommorow, cant find info on distripart cd, any suggestions please
    #187070
    Re: zan1415w wont start
    delta01 wrote:any suggestions please
    ZWF1415W maybe….? :con:
    ….in which case a duff Interlock? 😕 I could give Mystic Meg a call 😆 😉 😉 😉
    #187071
    delta01
    thanks martin hope your right , when the lady explained the fault it sounded like the machine briefly did something then stopped , so i discounted the door lock possibility,
    #187072
    cab
    most common fault on these are the drain pump, after locking the door should go into drain, if pump goes down to earth will blow board.
    cab
    #187073
    delta01
    thanks Cab, board has blown suspected door lock but will check pump , customer went for new machine
