Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › zannusi error code E90
- This topic has 11 replies, 6 voices, and was last updated 22 years, 3 months ago by
snuggles.
January 8, 2004 at 1:19 pm #5051
snuggles
ParticipantCan anyone enlighten me to what this code means….thanks 8)
January 8, 2004 at 1:23 pm #108448Dave_Conway
ParticipantRe: zannusi error code E90
Snuggles, what appliance is it you have ? And the model number would also help.
Regards
January 8, 2004 at 1:25 pm #108449snuggles
zannusi jet system 1200 model FJS 1225W…TA…
January 8, 2004 at 1:36 pm #108450Dave_Conway
Snuggles E90 is a PCB problem. It is either a communications breakdown between the two pcb’s or a software/configuration error. Either way it’s best not get involved unless you are an engineer with the facility to get hold of the configuration information for these machines.
If you need an engineer’s help, post you’re postcode area here and someone should be able to help you further who is local to you.
Hope this helps.
January 8, 2004 at 1:39 pm #108451snuggles
THANKS FOR YOUR HELP….I THOUGHT THIS MIGHT HAVE BEEN THE CASE AS IT WAS AN INTERMITTANT PROB…..CHEERS…BOB 😀
January 8, 2004 at 1:41 pm #108452Dave_Conway
snuggles wrote:THANKS FOR YOUR HELP
You’re welcome. 😀
January 25, 2004 at 6:49 pm #108453DentedPorsche
Glad I read this one. I’ve to see one of these machines this week giving error codes E20, E40 and E90. The configuration code is on the main pcb label. I have the information for configuring these but as it’s rather long winded (several pages) I’d have to send a copy.
April 21, 2004 at 6:46 pm #108454admin
KeymasterRe: zannusi error code E90
HOPE YOU CAN YOU CAN HELP! WHAT OES E90 MEAN?
CHEERS
ANDY COLEApril 21, 2004 at 7:59 pm #108455Dave_Conway
ANDYCOLE wrote:HOPE YOU CAN YOU CAN HELP! WHAT OES E90 MEAN?
Andy, the E90 error code is explained above.Dave.
April 19, 2005 at 8:33 pm #108456admin
I had an E90 error code (intermittent) and the engineer replaced the communications wires (5 blue wires with a plug on each end) apparently not an uncommon fault.
July 18, 2005 at 9:14 pm #108457deltra
had same problem last week.disconnected board,quick blast with hair dryer,reassembled,and worked atreat!!(condensaton ??)
July 18, 2005 at 11:31 pm #108458Penguin45
It’s a good theory. What has most likely happened is that by removing and replacing the connectors the contact surface has had any oxidisation scraped off, thus allowing a better contact.
Expensive electronic circuitry would use gold plating, which does not oxidise in the first place.
Penguin45. -
