Zannusi W/Dry ZWD16270W – C24 Fault code
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zannusi W/Dry ZWD16270W – C24 Fault code
  • #56141
    MickGeorge
    Hi folks
    Been to this today – m/c not starting or starts for 10sec with pump and shuts down.
    Put in diagnostic mode and comes up with a Ed4 fault when you go thru the component tests and C24 on last fault recorded test.
    Ed4 looks like wiring, t/dry pcb or main pcb altho manual lists it as ED4
    Wiring looks ok – put on t/dry and worked ok and manged to get the odd fill and pump out on the odd program but nothing consitant.
    Suspect main PCB unless anyone can shed any more light on this.
    Is a C fault a configeration fault? – Nothing listed on Distripart manual for this.
    Mick
    #326353
    pup
    Re: Zannusi W/Dry ZWD16270W – C24 Fault code
    first try dryer heater disconnect all wires ,had one last week doing same it was td heater 😆
    #326354
    As pup says, this is common fault on all Lux now. Where’ve you been, not to know that? 😆
    Dryer heater (apparently can also be wash heater in some instances), drops below 40Mohm ins. res. and electronics refuse to play. Check wattage of dryer ele as there are two versions 700+700 or 1000+1000 IIRC.
    Mike.
    #326355
    allan73
    Yep Dryer heater gotta be first port of call, if theres a thermistor at bottom of condensor assy wires break to them aswell.
    #326356
    MickGeorge
    Thanks guys
    Just puzzled me the fact that the t/drier was the only thing i could get on first attempt?? – and wierd fault codes not in manual? 😕
    Give the old mech timers anyday over all this electronic fandango stuff!
    Going back to day and have another look
    Mick
    #326357
    MickGeorge
    Spot on lads – lowish earh resistance – disconnect heater an workied ok.
    Just got to fit new heater 🙂
    Again many thanks folks
    Mick
