Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Zannusi Zwd1680W washer dryer 91460163800 serial no. 429 00
- This topic has 7 replies, 2 voices, and was last updated 12 years ago by
pl22ong.
March 29, 2014 at 3:38 pm #80146
pl22ong
ParticipantEntered a 30 minute wash cycle.Wash cycle completed satisfactorily,the proceeded to a drying programme of 15 minutes.Witnessed the start of programme, remember commencement by drum cycling. Left premises for short while during which time the RCD at main fuse board had tripped.
Reset it,it tripped again.
As a process of elimination, entered a spin only but after a short while RCD tripped again!!!
Have replaced Dryer element also Thermostat also overheat protection thermostat.
Can now conduct a normal wash programme satisfactoriy.
Setting a dryer cycle the drain clears and drum cycles BUT no heat!!!
Have 235 volt power at thermostats and element!!Have held pause and the next button selected first programme clockwise The LEDS flash released buttons LEDS scroll,rotated programme through each position clockwise to the off position.
Turned to a programme and then to off.
Reset a 15min drying programme, programmed commpleted BUT still no heat!!Any help please.
Frustrated Ernie. (80years old with a few marbles)
March 29, 2014 at 7:34 pm #411871Martin
ParticipantRe: Zannusi Zwd1680W washer dryer 91460163800 serial no. 42
Does the dryer fan operate? Have you checked the terminal connections to the NatC on the bottom condenser hose?
March 31, 2014 at 12:14 pm #411872pl22ong
Thanks Martin.
Yes the fan does operate
Not quite sure what you mean by NatC (what is NatC) on condenser hose Where is that in relation to facing front of machine
Please bear with me(80years with few marbles) the macine is closed up and used for wash only.
I am dependant upon my son visiting once a week to progress this
Please bear with me
I’m vewry greatful for your replyErnie James
March 31, 2014 at 12:40 pm #411873Martin
pl22ong wrote:Not quite sure what you mean by NatC (what is NatC) on condenser hose Where is that in relation to facing front of machine
Sorry for NatC, instead read NTC (iPad typo error) 🙁
The NTC (thermistor) is located in the bottom black rubber hose that connects to the condenser matrix on the right hand side.
March 31, 2014 at 8:23 pm #411874pl22ong
Thanks Martin
Will keep you informed
ernie James
April 25, 2014 at 12:08 pm #411875pl22ong
Martin sorry for delay in replying
My son has checked thermistor connections and all seems ok.
Have disconnected large plastic chamber full of fluff etc and cleaned
White pressue switch and black pressure switches seem to work with air (mouth) applied.
to recap power at all connections on heater fan works but!!!!!!
Any further advice please?Thanks
Ernie 80 something
April 25, 2014 at 1:55 pm #411876Martin
Dunno to be honest from this remote location. There are no less than 2 t/stats and one NTC on the dryer heater box. One t/stat is a safety overheat/manual reset job the other a regular auto reset t/stat. And the one on the front is an NTC that monitors the hot airflow. The NTC below the condenser matrix measures the warm air flow.
I’ve no idea what caused the RCD to trip in the end, was it a faulty dryer element or what exactly?
April 25, 2014 at 5:01 pm #411877pl22ong
Thanks Martin
If I find anything of interest I will contact you
Ernie 80 something
