hi this machine runs for about 10 mins then just shuts down i strongly
suspect the module any help appreciated also is this one of those Chinese versions i have heard of, thanks
You mean ZWG1120m and yes its one of those Chinese creations. Had one the other day with a blocked pump on a chargable basis which was good so maybe worth a visit to check for that at least.
hi captaincaveman1 i had already checked the pump and pipes for blockages nff, it seems like if you leave it for a while it will work again but then it cuts out again
Motors are favourite on these as well. There is a service mode on this model which is available to view on TDS but Im useless with link’s So maybe someone could point you the right way!!!
