Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Zannussi Aquacyle 1400 fx1465 5 beep/flash end light fault
- This topic has 7 replies, 3 voices, and was last updated 21 years ago by
admin.
March 23, 2005 at 3:21 pm #8646
KeymasterPower on select program and unit beeps 5 times with end led flashing 5 times and nothing manual only goes up to 4 can you help
March 23, 2005 at 3:39 pm #129803johnboy
ParticipantCheck out the motor and pcb
March 23, 2005 at 3:42 pm #129804admin
KeymasterRe: Zannussi Aquacyle 1400 fx1465 5 beep/flash end light fau
motor looks fine and PCb looks like a pcb brushes good ect, windings giving continuity.
I thought there might be a definitionn to 5 beeps to point me in the right direction
March 23, 2005 at 3:49 pm #129805Martin
ParticipantRe: Zannussi Aquacyle 1400 fx1465 5 beep/flash end light fau
Lexotron,
You need to run that by us again by counting the flashes you get from:-
A) = The “End” LED?
B) = The “Start/Pause” LED?Also please let us have the machines Product Numbers (By the Door seaL)
March 23, 2005 at 3:54 pm #129806admin
are you sitting cofortably Martin,
Select any Program,
Single bleep no lights, followed by 5 bleeps with end light 5 flashes.
Product No.914792705 00
March 24, 2005 at 10:29 am #129807admin
Apparently you press and hold start pause button and turn program selector clockwise to position one, and the leds will begin to sequence, release the buttons and carry on turning to position 10, this should reveal a fault code.
In my case in position 10 all lights are extinguished.
Hope this is some help.
April 1, 2005 at 1:07 am #129808admin
Gave up waiting had to call zanussi £56 call out charge cheers guys, will post result of call out to save others.
April 19, 2005 at 1:32 am #129809admin
PCB had to be replaced aparently fault code was a motor fault but motor fine, failed part was a trysistor on the pcb showing oc about 80p to relace repair cost 210 pounds.
Zanussi will reinburs 70 {e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} jobs a good un
