Zannussi E80
  • #21943
    pmb
    Zanussi WJS1465W Taken Machine away to do drum bearings
    user tells me she sometimes gets E80 fault code
    Its not in my error codes
    Any ideas
    #193108
    Re: Zannussi E80
    E80 is the user code – go into diagnostics and you should get E82 or 3 –
    the answer to which can be found on P4 of the Known Error Code thread.
    aqualectric
    Re: Zannussi E80
    Zanussi E80 codes relate to recirculating pump problems or possibly PCB failure.
    Either:- Pump or associated system blocked; wiring problem; recirc. pump shot; lastly main PCB fault. (sensing on recirc. pump triac).
    Hope that helps,
    Steve.
