zannussi progress 1400
  • #99578
    Soulfly83
    Hi, a family member has a washing machine problem..
    its an older zannussi progress 1400. it gets so far into the cycle and then stops, it does fill with water and spins. turn machine off then back on and select drain and it drains like it should. ive removed the filter at the bottom, was a 5p in there, seen worse
    looking for ideas, i know the brushes have been replaced maybe once or twice over the years. i havnt checked them for her. she things the water isnt getting hot, boil wash and going on touch of the glass door. tried different cycles, no difference.
    #476955
    what you need to figure out what its trying to do when it stops
    Soulfly83
    It’s not displaying a error code this time. She says it happens 5 mind into, she thinks it’s when it’s supposed to heat water to temp
    #476957
    right so it fills with water y/n
    does the motor move ?
    if it is a heat problem does it work ok on a rinse programme ?
    have you got the model number so i can know which system your talking about
    Soulfly83
    electrofix wrote:right so it fills with water y/n
    yes it fills with water
    this is how she describled the rinse cycle: It went to 18 mins from 24. Which took about 20 mins…. Then it jumped back to 25 mins.. Paused itself with light flashing
    zanussi progress 1400 Zwf 1431 s i can go down and try find a tag with model number is that isnt anygood.
    #476959
    am interested in the flashing
    faults on this model are indicated by flashing lights. look to see if there is a sequence to the flashing
    look at the start button and also the programme end light
    Soulfly83
    First time we’ve noticed it, it normally gives a error code for brushes and there was something else. I’ll try get a look at the lights. It’s and old machine, I couldn’t see it when searched the model. Thanks
    #476961
    machine built between 2005 and 7
    parts breaskdown here
    https://shop.zanussi.co.uk/search?text=91452120200
    there are 3 of them and they all have different pnc numbers so i picked one at random
    dave
    #476962
    Soulfly83
    do these help?
    #476963
    Soulfly83
    Anyone any ideas before she buys a new machine? Cheers
    #476964
    Soulfly83
    Anyone any idea before she buys a new machine? Cheers
    #476965
    only just picked this up as i have been away
    did you check the brushes ?
    in case they are intermittant
    Soulfly83
    sorry, it got scrapped 🙁 thanks for the help
