Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Zannussi washer dryer
- This topic has 6 replies, 5 voices, and was last updated 21 years ago by
pmb.
March 28, 2005 at 12:09 pm #8721
pmb
ParticipantZannussi WJD1257W. Original fault code E90, fitted new programme module. Now rinse light flashes and buzzes and unable to configurer. Have I got a new faulty module? Have also changed display module, no difference to either module faults. Checked all connections.
As I have two different faults, I suspect new module is faulty. Have you come across this problem? Any suggestions will be greatly appreciated. ❓March 28, 2005 at 7:09 pm #130152Dave_Conway
ParticipantRe: Zannussi washer dryer
I have had one new PCB that was faulty, pretty similar symptoms, unable to configure, no test more etc.
The only sure way is try another one I guess 🙁
March 28, 2005 at 8:18 pm #130153Flyman
Put the old module back in then go into fault system to check the fault code and it should give you E91,E92 etc. Have found in the past that if there is a fault on the machine it will not let you configure a new board. Have had a few problems with the small ribbon cable between the two boards, it would be worth while trying a new one of those in if you have one.
March 29, 2005 at 8:33 pm #130154farmboy
E91 – remove fascia & unplug blue ribbon cable from display pcb.
carefully bend the pins of the ribbon connector back towards the centre of the plug, re attatch to the display pcb & refit fascia, shouldnt need any new parts if its E91 in the memory, its also worth clearing the machine fault memory.April 1, 2005 at 5:04 pm #130155pmb
THANKS FOR THE INFORMATION, ITS NOT THE RIBBON,CUSTOMER HAS DECIDED TO GET A NEW MACHINE, SO I CAN TAKE MY TIME, GO BACK TO IT WHEN I HAVE TIME,3YEARS OLD, A GOOD RECON 🙄
April 16, 2005 at 8:35 am #130156andy_art_trigg
pmb wrote:THANKS FOR THE INFORMATION, ITS NOT THE RIBBON,CUSTOMER HAS DECIDED TO GET A NEW MACHINE, SO I CAN TAKE MY TIME, GO BACK TO IT WHEN I HAVE TIME,3YEARS OLD, A GOOD RECON 🙄
Have you had another look yet? Just curious as to the result.
Andy
April 18, 2005 at 4:23 pm #130157pmb
NOT YET. I HAVE BEEN OUT OF ACTION FOR A COUPLE OF WEEKS, WAS STACKING MACHINES DONE MY BACK IN,ITS GOOD ITS BEEN QUIET, AND MY SON WORKS WITH ME.I WILL CHECK IT AGAIN, IF IT IS A FAULTY NEW MODULE MY ONLY OPTION IS ORDER A NEW ONE 😕
