zannussi zwd12770 washer dryer
Home Forums Public Support Forums Help And Support Washing Machine Help Forum zannussi zwd12770 washer dryer
  • #67732
    russell knights
    not heating on wash side
    no live to heater on cycle,goes through prog ok
    element tested,wires ok
    any clue ?
    #368312
    BigCol78
    Re: zannussi zwd12770 washer dryer
    Check the main module (control PCB) for dry joints thats connections on the back of the PCB that look cracked or burned. If the PCB looks ok and the heater and wiring is ok its probably the main module at fault. Dont forget always make sure the machine is turned off and unplugged befor working on it.
    Hope you fix it BigCol.
    #368313
    russell knights
    send board of for testing,was repaired,still no heat,found new ntc limiter to be faulty as well
    cheers
