zanssi dishwasher heats occasionally
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries zanssi dishwasher heats occasionally
  • #95574
    slyp98
    Hi all , I have this zanussi pnc 91151914803 only heats when it wants , checked all the usual loose wiring , broken wires in door , i dont see a thermostat but i see there is one available anyone come across one of these thanks
    #460785
    baron
    It can be; tacho; NTC&OWI; analog pressure switch… but any of them should gave errors at least inside memory. You should read which one is it. (last tree are stored).
    Just after that I can try to help.
    #460786
    slyp98
    Thanks Baron, i wonder if there is engineers manual Available for this model,
    #460787
    slyp98
    I fitted a pressure sensor kit to one of these a few months back for issues with not draining , could this cause a non heating issue
    #460788
    baron
    slyp98 wrote:I fitted a pressure sensor kit to one of these a few months back for issues with not draining , could this cause a non heating issue
    It could be or not…
    When you fitted the kit did you run the service program? in order to calibrate the sensor? Read the errors, test each perpheral and run the test.
    tech info I can’t sent because of size limitation.
    #460789
    slyp98 wrote:Thanks Baron, i wonder if there is engineers manual Available for this model,
    manual should not be a problem
    let me have an email add
    slyp98
    baron wrote:
    It could be or not…
    I didnt run any service program as i wasnt aware of it , i never got any call to say there was a problem since
    #460791
    baron
    slyp98 wrote:
    I didnt run any service program as i wasn’t aware of it , i never got any call to say there was a problem since
    It doesn’t mean that is right this way.
    It’s best to do like previous pressure sensor changing instructions:
    Run the line test to calibrate the correct parameters of pressure sensor.
