Zanusasi FJ1254W Reading the fault code
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanusasi FJ1254W Reading the fault code
  • #72488
    johnnyj
    Hi Guys was at a Zanussi FJ1254W 914512815/00 washing machine for a letting agent, tenant is indian so couldnt explain in great detail what was wrong they have had the drain fixed for a blockage but the washing machine is faulty doing silly things, i put machine through diagnostics test it fills okay but when it heats with recirculation pump running after about 5 mins the 2nd and 3rd progress light flashes with last one also flashing is this an error code i think it might be 61 i’ve checked the ntc and wiring so i think it might be module JJ.
    #384646
    repman
    Re: Zanusasi FJ1254W Reading the fault code
    It is E61 heating time out so if the heater and ntc check out its time to get the soldering iron on the board
    jim
