I have been out to a Zanussi IZ161 prod no 91451309700 washing machine that when its switched on the pump is permanently energised. Does any one have any ideas? Thinking possibly board fault? Cheers Kez
Pressure switch on overfill duty (bottle blockage) or stuck / burnt pump triac (PCB failure). If the machine will run the diagnostics, then it would flag up an E20/ E30 fault code.
