Zanusi W/M ZWF12170w
  • #51340
    fidder
    This machine will not rotate. There are no brushes on this model so could do with some help on what the fault may be..cheers lads
    #307699
    Seamy
    Re: Zanusi W/M ZWF12170w
    PNC to know correct machine..
    Sounds like you have the one with the 3phase inverter driven motor. Check cable connections are good as i’ve had a few with broken cable at motor plug. Otherwise it can be main board, inverter board or motor. Make sure power is off quite a while before touching inverter board as they can hold charge for a while and give nasty shock.
    5pin motor connection, pins 4&5 are tacho, pins 1-2-3 delta connected.
    8pin motor connection, pins 7&8 are tacho, pins 4-5-6 delta connected, pin 2 is earth.
