Zanusi ZDV12002FA dishwasher
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Zanusi ZDV12002FA dishwasher
  • #95884
    Caraman2
    Dishwasher goes part way through cycle but stops after rinse and gives 2 beeps, does not progress and handbook suggests that drain outlet is blocked. Checked drains are clear and not kinked water pumps out ok. Any help appreciated.
    #461605
    steveDAS
    is the out let pump blocked, might be some glass in it
    #461606
    andyjawa
    Could be the pressure switch thinks it still has water in the machine so does not refill. Power off r/h/side panel off. Should see towards the front of the d/w a black pressure switch with 3 oe4 thin wires and a pipe that goes to the sump. remove the pipe off the p/swt, have a cup of luke warm water in the old gob and blow this water through the pipe, reconnect and see if anything improves. Can also be poor filling via l/h/side fill matrix as the air break gets limed up at the top where the elongated C shape is moulded into the matrix.
