hi been out to a zanuusi pumping prob so unblocked outlet hose and replaced pump but now here is the prob lights go across and down side. you start machine it fills then all the lights down the side flash about 4 sec then second one from bottom flashes then all the side ones flash again so i cant find this fault code as the start button dosn’t flash Help ?? did look at the dvd fault codes butt that got me more confused as light light went theone thay said on it 😳 💡 did take small film with my phone
Have sent you the diagnostics bumf. If it won’t access the diagnostic cycle, the board has definitely failed. Had teh pump you replaced actually blown?
it did go in to diagnostics mode the only think when it fills normaly it stoped at right places, but when when in diagnostics mode it filled half way up door so went on to next step theonly light thtflashed wee the ones down side .
