Zanusi ZWF1621W Sticks on last rinse
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanusi ZWF1621W Sticks on last rinse
  • #77555
    Twoten
    The above machine goes through the wash and sticks on final rinse full of water.
    Rinse hold is not selected.
    The Start/Pause button flashes continually (no pauses).
    No other lights are on or flashing.
    To restart the machine it has to be turned to ‘0’ and then set on spin.
    A wash that should take in the region of 90 minutes is taking about 150 minutes.
    There is no earth fault and the element tests OK.
    I have run through the test sequence without any problems.
    Any suggestions would be appreciated.
    #402593
    Andy jones
    Re: Zanusi ZWF1621W Sticks on last rinse
    Is it taking the conditioner. Could be that valve
    #402594
    Twoten
    The machine is taking the fabric conditioner.
    The valve worked when I went through the test sequence.
