Integrated slimline dishwasher is leaking into the base via the black overflow tubes due to it not stopping water going in. Someone else has been there before me and they have changed the pressure switch and water inlet valve. I double checked on this and this test all good, also no holes or leaks on the pressure switch hose.
Has any one come across this before, when I mean it leaks into the base I mean it pours, it doesn’t just drip. As far as I can tell it is the PCB not switching of the water inlet valve, but I am not sure if there is another sensor on this models that is checking the water inlet pressure. Only 18 months old. After the previous guy changed the 2 parts the customer says that it worked for 2 weeks but then started again.
Any help will be much appreciated.
Thanks.
