Zanuss washer dryer ZWD 14270w
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanuss washer dryer ZWD 14270w
  • #76835
    winker
    This machine has error code E24.Power button on and cycle selects ok.The cycle starts without pressing start button,the pause button has no effect and the spin speed indicator is locked to cancel.Machine defaults to zero and door unlocks.
    If this machine needs new pcb does is come configured.Your thoughts on diagnosis welcomed
    #399949
    Re: Zanuss washer dryer ZWD 14270w
    Sounds like the pump has taken out the PCB. 😥
    #399950
    winker
    thanks for the reply,i was thinking that way,the pump still works tho ? can that that be ?
    #399951
    E24 is supposed to be a pump triac fault, I think you can get the boards programmed or not.
    #399952
    I’m thinking it could be the usual dryer heater earth leak causing all this mayhem?
