Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › zanuss zbf 360 oven door
- This topic has 5 replies, 2 voices, and was last updated 20 years, 5 months ago by
neilshrops.
November 15, 2005 at 9:59 am #13308
neilshrops
Participanthello all, my oven door is damaged beyond repair and out of guarantee, I’m waiting for a call back from the service centre but I just wondered if it was possible to get hold of proprietry oven doors if I’m unable to get an original part and if so where from? and also where to try (apart from Zanussi to get an orginal one from.
many thanks.
November 15, 2005 at 10:42 am #154171Dave_Conway
ParticipantRe: zanuss zbf 360 oven door
It’s highly unlikely anything but the original will fit, you also won’t be able to buy a whole door, each part is seperately supplied.
If you can pop up the PNC (product code) beginning with 949….. I can check availablity for you, there are 6 versions of this oven.
November 15, 2005 at 10:59 am #154172neilshrops
forgive my naivety, but where do I get the number from? I only have the manual which seems to be a generic one applying to all ‘360s, is it written somewhere on the oven?
Thanks.November 15, 2005 at 11:06 am #154173Dave_Conway
No problem 🙂
It should be around the door frame area on the rating plate, essentially it denotes the colour/style so if you can’t find it, that may narrow it down a bit.
November 16, 2005 at 7:38 am #154174neilshrops
right all the info is:-
model:- zbf360w
Prod no:- 949711203
Type:- A9657/133n
Serial No:- 24817841November 16, 2005 at 8:56 am #154175Dave_Conway
OK, here’s everything to make the door up apart from the screws which should be re-usable from the old one:
Inner door – 357 83 39-11/5 – £29.18
Outer glass – 357 82 95-74/7 – £45.56
Hinges – 358 19 05-49/8 – £7.82 each
Door brackets (inside door) – 353 01 84-03/9 and 353 01 84-04/7 – £3.36 each
Door handle – 355 40 52-02/1 – £14.38
Door handle spacers – 354 30 15-10/5 – £3.53 eachAll the prices inc VAT, depending on what parts are actually required the carriage will vary due to the weight but expect somewhere between £10 and £20.
An email to spares@ukwhitegoods.co.uk please to order any of the above. 🙂
