Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Zanussi 1225W Stops after 4 seconds
- This topic has 12 replies, 4 voices, and was last updated 20 years, 3 months ago by
Plastic_Bonsai.
December 29, 2005 at 10:30 am #14351
Plastic_Bonsai
ParticipantWonderful site you have here.
The machine runs for about 4 seconds of its program and then stops with the start button LED flashing. There are no error codes. The inlet filters and the exit filters are clear – the machine drains OK but it doesn’t start to fill or turn the drum on a spin cycle. The drum turns by hand OK.
Other symptoms have been that is has occaisonally stopped in the program but it restarted OK after the obligatory filter clean but it also seems to take long time to complete a full program (2-3 hrs).
I have looked through all the threads in this forum and this seems similar to another report and I think the solution was the motor brushes wearing out. If it is this are they easy to get at and replace?
December 29, 2005 at 10:44 am #159118Martin
ParticipantRe: Zanussi 1225W Stops after 4 seconds
I guess you refer to an FJS1225W ? In which case it’s possible the Door Lock is at fault?
December 29, 2005 at 10:47 am #159119Goatboy
Plastic_Bonsai wrote:…it doesn’t start to fill…
That sounds like your problem to me!
Investigate that bit a little further. Put it on a program, press start, then open the soapbox, and see if any water is comming in.
If it’s not filling with water, it will go into fault mode, as you described.
Maybe a frozen fill pipe? It is very cold today?
December 29, 2005 at 10:49 am #159120Goatboy
:wave: Hi Martin!
Good point! Is it locking the door Bonsai?
December 30, 2005 at 7:44 am #159121Plastic_Bonsai
Thanks for the prompt replies.
It is an FJS 1225 W.
No water comes in but the inlet pipe is fine. It is very cold today but it has been out of action since Xmas Eve (typical domestic appliance timing).
The door does lock OK – I have to turn the unit off with the front switch and then on again to deactivate the lock.
As I said the unit runs for about 4 seconds- sound of the drain pump going – it does drain fully if I put some water in the drum – and it stops at the point when I would expect to hear water being let in – not a trickle in the soap tray.
If I move it on to a spin cycle however it stops again at about 4 seconds in. The drum doesn’t move though it is free to rotate – drive belt is OK.
Other possible symptoms:
Generally took 2-3 hours to do a 1 hour program
The area’s water is hard.
Unit is about 3 years old but used almost daily. Seems to be in good nick generally.
I am generally unluckyDecember 30, 2005 at 9:31 am #159122Dave_Conway
Plastic_Bonsai wrote:No water comes in but the inlet pipe is fine.
Have you disconnected the hose from the appliance and then turned the tap on (aimed in to a bucket ;)) ?
It sounds to me like no water is reaching the machine, either that or the fill valve may have failed.
December 30, 2005 at 11:41 am #159123Plastic_Bonsai
ParticipantYes I have just checked that again to be sure.
Would the stuck inlet valve stop the machine working if the spin cycle was selected? Logic (if that has anything to do with Washing Machine programming) would suggest not but it could be.
Is it easy for me to check the motor brushes?
December 30, 2005 at 1:29 pm #159124Plastic_Bonsai
ParticipantAfter a bit (understated) of effort I have got the back off (the trick is the hidden bolts on the sides). I have checked the brushes and with 20mm on them I think that they are OK. So the heck with logic – it’s probably the inlet valve. As it is cold fill only can I be crafty and swap them around?
December 30, 2005 at 1:54 pm #159125Plastic_Bonsai
ParticipantOK I managed to swap the plugs around with a little help from Mr Stanley Knife to remove the keyway. Unfortunately no change except it now shows E90 so it’s probably spotted my sabotage. Impressive – except it can’t tell me what is actually wrong with it. Anyway I’ll swap them back and throw in the towel (fuguratively) and seek professional help.
Thanks for the help. If it gets fixed I will post the solution here.
January 5, 2006 at 11:29 pm #159126Plastic_Bonsai
ParticipantThe repair man cometh and after a while announced that it could be the computer board and that the outlet is gunged up and the pump is on its way out so it looks like after 3 years its heading for the land fill. It seems a terrible waste but that’s the way Economics is making our planet a rubbish tip of un-economic-to-repair appliances. I noticed a Boch 1400(?) machine for sale at about £269 but I can’t afford anything until next month so hopefully we can survive with a local laundry if they still exist.
January 6, 2006 at 9:00 am #159127Martin
We appreciate your posts and keeping us up to date on your story that is often typically experienced by many like you 🙁
January 6, 2006 at 2:52 pm #159128Plastic_Bonsai
ParticipantS’Aright.
I have much appreciated the help and that a site such as this exists. I hope your ISE is a real winner and cuts down on the scandelous wastage.
Meanwhile a colleague has offered an old Indesit machine with a slightly leaky door seal (which we can cope with) to tie us over. I may be asking if it’s possible to replace the seal soon!January 8, 2006 at 4:18 pm #159129Plastic_Bonsai
ParticipantI just tried the machine again before taking it to the dump. It looks like the repair man left it in diagnostic mode and it happily filled and turned the drum etc. On re-cycling it went back to it’s old troubles so it is the computer. Preety galling.
