zanussi
  • #32677
    waters
    Model ZWD 14270W error 10.Triple valve ok but does not fill.Spin, pump and dry ok but selecting a wash program gives E 10.
    #235997
    aqualectric
    Re: zanussi
    Can’t find that model number – ZWD14270W not on TDS. Can you post the PNC number?
    Steve.
    #235998
    waters
    Re: zanussi
    The machine is only a couple of months old
    #235999
    TELL
    Re: zanussi
    Table of alarm codes
    Alarm Possible fault Action/machine status Reset
    E11
    Tap closed or water pressure too low; Drain tube improperly positioned; Water fill solenoid
    valve is faulty; Leaks from water circuit on pressure switch; Pressure switch faulty; Wiring
    faulty; PCB faulty.
    Cycle is paused with door locked. START/RESET
    E12
    faulty; PCB faulty.
    E13
    Drain tube improperly positioned; Water pressure too low;
    Water fill solenoid valve is faulty; Water circuit on pressure switch is leaking/clogged; Pressure
    switch faulty.
    Cycle is paused with door locked. START/RESET8 ALARMS
    8.1 Displaying the alarms to the user
    The alarms are displayed by the red LED of the START/PAUSE button flashing and simultaneously through the
    LCD or Display.
    The alarms displayed to the user are listed below:
    �� E10 – Water fill difficulty (closed tap)
    �� E20 – Drain difficulty (dirty filter)
    �� E40 – Door open
    only thing i can find. hope this helps.
    TELL.
    #236000
    lerch
    Re: zanussi
    E10 error is one of the triple inlet valves are faulty.
