Zanussi 812 won’t rotate with full load
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanussi 812 won’t rotate with full load
  • #80623
    Wilberforce
    My Zanussi 812 drum will not rotate with a full load. It works fine with a part load. The belt is not slipping and pullies are firm on the spindles. Drum and motor bearings are all OK. I’ve removed the motor and it spins freely but it looks as if the motor has to be taken apart to get to the brushes. Not done that yet. Any suggestions please.
    #413500
    Re: Zanussi 812 won’t rotate with full load
    If your machine is an FL812 ?? Then the motor doesn’t have brushes (induction motor) and the problem is more likely the start capacitor.
    #413501
    Wilberforce
    Hi Martin, thanks for your reply. Yes, it is the FL812 with SOLE 20571.517 motor. If there are no brushes, I won’t take it apart to find them 😀 .
    If a faulty start capacitor can give the impression of a ‘weak’ motor that could certainly be it. I’ll change it. Any suggestions on where I will find it? There is no obvious capacitor on the motor.
    Thanks again
    #413502
    Wilberforce wrote:Any suggestions on where I will find it?
    Power off first! :zap:
    Remove the lid and it is attached under the metal cross member.
    #413503
    Wilberforce
    Thanks Martin. Power is off 😀
    But I’m really struggling to find a new capacitor. So far nothing at ukwhitegoods or espares. Ebay is full of various ones but I don’t think match the one I want. Any suggestions?
    Cheers
    #413504
    What is it rated at? (I can’t recall but think it is 16uf?)
    #413505
    Wilberforce
    Hi Martin,
    I think the capacitor I need is 12.5?F. I have managed to find and order one so and will try it when it arrives.
    There is also a smaller capacitor with the following markings:
    411.13.608
    KTO,039 microF (X2) +
    2 x 0.039 microF(4)+2,2,MOhms
    250vAC HPF258521
    I can’t find a replacement for this one so I’m hoping it’s the larger one.
    Many thanks for your help.
    #413506
    The small one is a mains suppressor and to be ignored.
