zanussi 911516190/05-zdf26011wa
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries zanussi 911516190/05-zdf26011wa
  • #92133
    eng14
    hi put new heater on the end of this wash pump one month ago.i thought things were bad its gone again no heat.ideas 😕 richard
    #450381
    Seamy
    Re: zanussi 911516190/05-zdf26011wa
    First check filters are clean, scum off plastic from tablet covers that should dissolve but won’t on low temp’/short programmes can cause problems with flow rate, if poor water flow through heater it goes open circuit on t.o.c’s .
    Same story with circulation pump, also pressure sensor causes same problem, if appliance doesn’t fill to correct level or no water pressure from circ’ pump, the heater goes open circuit via t.o.c’s mounted on heater.
    All heaters i’ve changed (dozens of them) have gone open circuit on t.o.c’s rather than open circuit element, proving that its lack of water rather than heater failure.
