Zanussi 914787006 Belt ??
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Zanussi 914787006 Belt ??
Viewing 15 posts - 1 through 15 (of 15 total)
  • #100403
    RocketMan
    I need a belt for this venerable oldie.
    Details off the front are Prod 914787006 (no other numbers)
    Model FJ 1033/B
    I have already ordered 1108786003…it’s just slightly too bit too loose. it’s a 1282 6PJE.
    A quick search has thrown up1323531002 which is 1200 which is just way too small? 1282 above is just slightly bigger.
    I’ve just managed to get a number off the old belt (by shining a very bright torch behind it and it’s shown up the part number even though it’s not visible to the eye at the front).
    124021010 Megadyne 1200 J6
    Can someone confirm that that’s the correct part number? It seems quite a bit smaller.
    #480465
    RocketMan
    electrofix wrote:correct part no 50220805001
    1200 J6
    https://shop.ukwhitegoods.co.uk/1240210102-washing-machine-drive-belt
    Thanks Dave. As ever, you’re a top man.
    #480467
    RocketMan
    Hi Dave,
    Having a nightmare with this job. The belt that came off was marked 124021010 Megadyne 1200 J6.
    I went back armed with a 1200 belt 2nd time(not gen but pattern)…still too big. Back half off. Checked for excess play motor and drum bearing…no issues.
    Measured the belt that came off. I cut the old one to get a more accurate measurment. 1175mm approximately. Even though it’s marked 1200.
    Am I missing something?
    I’m losing the will to live with it. Not a short distance away either…Seriously lost out.
    #480468
    what was the belt you tried to fit
    part no ? of the pattern one
    murv
    This is an elastic stretch belt (1200J6EL) so will be shotrer than the stamped/running length.
    Stretch belt length depends on material, thickness, width etc but I would expect a new 1200mm belt to be at least a couple of inches shorter than the running length.
    Have not got a 1200J EL on stock but have checked the following new stock
    1196J6EL (plastic belt) – measures 1156mm
    1195J5EL (rubber belt) – measures 1137mm
    1230J5EL (rubber belt) – measures 1184mm
    Murv…
    #480470
    murv wrote:This is an elastic stretch belt (1200J6EL) so will be shotrer than the stamped/running length.
    Murv…
    was why i was asking part no of belt he tried to fit
    was wondering if the belt he has was non stretch
    murv
    Undestood Dave,
    Some suppliers still get it wrong and list a standard polyvee as a pattern replacement for an elastic one.
    Thought it would be helpful to point out just how short the correct stetch belt is likely to be.
    Murv…
    #480472
    murv wrote:Undestood Dave,
    Murv…
    was a good point to make. will enable him to measure the one he has got
    RocketMan
    electrofix wrote:what was the belt you tried to fit
    It was an Electru I think? 1200J5 BLT9016. (it’s in the van and it’s freezing atm)
    #480474
    RocketMan
    The orginal belt 124021010 Megadyne EL 1200 J6
    #480475
    measure the new belt you have got from connect.
    when a stretch belt says 1200 mm it means 1200 when stretched
    as murv pointed our the unstretched belt should be about 40mm shorter
    my bet ( and murv seems to have same opinion) is you have been sold the wrong part
    RocketMan
    I did give the correct part number to the shop that supplied me. I guess it looks like they’ve supplied a 1200 belt instead of a 1200 elasticated stretch belt.
    #480477
    murv
    124021010(2) Converts to BLT3783 which should be a 1200mm elastic belt – Sadly Connects description does not confirm that it is elastic (No wonder they get confused!)
    I think you may have BLT9017 which is definately a 1200mm standard polyvee belt
    #480478
    RocketMan
    murv wrote:124021010(2) Converts to BLT3783 which should be a 1200mm elastic belt – Sadly Connects description does not confirm that it is elastic (No wonder they get confused!)
    Thanks. I think you’re correct. I don’t use Connect. A friend has a shop and things have gone wrong here. I’m going to order the correct belt 1200 EL J6. 3rd time Lucky. Thanks for you time.
