zanussi adp5966 F7 WARNING
Home Forums Public Support Forums Help And Support Dishwasher Help Forum zanussi adp5966 F7 WARNING
  • #16093
    platespinner
    Hi.
    Every time I try to wash the dishes, my two-year-old Zanussi ADP5966 puts up an F7 warning on the panel. I’ve tried running a few litres of water through it, which has cured it in the past, but this time the error won’t go away. Any ideas anyone please? 🙁
    #167514
    clivejameson
    Re: zanussi adp5966 F7 WARNING
    Hi platespinner
    The model number you quote is a Whirlpool model number!
    The fault code relates to a water level problem….the first things to check are the filter, fill hose and drain hose for blockages/kinks.
    If you still have a problem then you will probably need an engineer to sort it for you although it may not be serious.
