Zanussi Aquacycle 1400 – Start / Pause light flashing
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanussi Aquacycle 1400 – Start / Pause light flashing
  • #39474
    Dabchick
    Fairly old washer. Switched it on to do a wash, set the programme. Door lock light goes on, but doesn’t wash and Start/pause light flashes. Skip button works (cancels programme lights) and start/pause buttin beeps, but can’t get anything else to happen. Have powered off, opened door etc.
    Sounds terminal ? Any ideas ?
    PS: Been camping, 3 loads of washing waiting.
    #262532
    Re: Zanussi Aquacycle 1400 – Start / Pause light flashing
    Model number please, DC.
    Dabchick
    Sorry – FLE1416W
    #262534
    Dabchick
    Lost the manual and can’t find anywhere to download it from. Zanussi site is rather less than helpful
    #262535
    Dabchick
    Fiddled with the Zanussi site and managed to download the standard user manual. Suggests that the inlet filter might be blocked (doubt it as this is a sudden problem). Anyway, took the hose off the back of the washer and the fliter looks clean (should it come out for cleaning ?).
    #262536
    Dabchick
    Sorry – let me put some more detail on this.
    When I switch the washer on, none of the programme lights show up. They can then be set by repeated pushing of the buttons. As soon as I push any of the buttons, the pause light starts flashing.
    #262537
    Rich5987
    Did you manage to get this sorted, I have exactly the same problem with teh same machine..
    I’ve tried everything.
    I had to force the door open to get my washing out.
    I have found if you hold down teh start and skip buttins then turn it on the lights go through a blinking sequence, as if resetting, but it hasn’t changed anything.
    Would love to know if you’ve fixed it.
    Rich
    #262538
    TheSpinDoctor
    Hi.
    Has the drain filter been checked. If not, check & clear as per instruction manual & re test.
    #262539
    sheer1delight
    Sounds like faulty door interlock. Power off. Remove ring round door gasket. Unscrew front screws holding interlock in place. Pull back gasket and remove from wiring and replace.
    #262540
    TheSpinDoctor
    I have just re read the previous post where it says:
    That is you entering the diagnostic which if you don’t know what you are doing is a very bad idea as it is possible for you to change the configuration code which is a 16 digit hexadecimal code. If you have managed to do that your machine will not work until it is corrected.
    #262541
    Rich5987
    Mine is working again now, left it over christmas and it works.
    Looks like i didin’t manage to change the hexadecimal code! luckiliy!
    I’m going to buy a door lock just in case it happens again as our clothes were looked in for quite some time!
