Zanussi Aquacycle model FS1555W
Issue
will not drain everything else ok
Error checked as
2x flashes beeps End Cycle button at the same time
2x flashes beeps Start pause button at the same time
there is a pause then
1x flash on the start pause button
stripped out door mech all looks and seems to be working ok including light
stripped all sump pump and hoses cleaned them all out including the plastic ball in the sump hose.
blew clean the pressure hose reconnected all
old pump was melted on coil and was showing below 150oms So fitted new sump pump Askol replacement bayonet type UN51203
still got same error beeps and flashes
and washer will still not drain
is this the triac or pcb
as stated everything else works it goes through full cycle from filing up to agitating water into spin mode but will not drain.
have even cleaned out drain hose and all external piping but to no avail.
any help would be appreciated as this has me stumped
