Re: Zanussi Aqusave DES959 Error Code AL5
AL5 as you have discovered relates to “Fill time-out” 🙁
Usually associated with either a faulty fill matrix, flood safety system activated, blocked inlet filters, insufficient water pressure, central filter clogged etc etc.
Those are the likely things to check and I would recommend you call in an expert before getting yourself into trouble on this one. We may have someone that covers your area and you can contact directly for advice. (See link below)
Repairs@
