zanussi auto flashing E90
  • #32767
    monkey
    Does anyone know what the error E90 is
    monkey
    #236329
    Re: zanussi auto flashing E90
    That is the customer code, need to interrogate the pcb on the test programme to find the actual code.
    #236330
    aqualectric
    Communication fault between user interface and PCB. (fascia PCB and power board). Usually the connections on the fascia are oxidised and just need cleaning.
    Remove the fascia, disconnect the wiring plug, carefully remove the board from the fascia and clean the edge connections. Then refit into fascia and gently pinch the plug with pliers to tighten it before fitting. Refit fascia and all should be OK. If not, check the loom between the fascia and the main PCB. If that’s OK, then it’s PCB failure.
    Hope that helps,
    Steve.
    #236331
    monkey
    thanks I found the pump was sticking
    monkey
    #236332
    monkey wrote:thanks I found the pump was sticking
    monkey
    😯 =E90 :hmm: :rotfl:
