i’m looking for a condensing tumble dryer which will be connected to a drain at the moment.
i’ve found a zanussi ZDC37202W and checking the manual it says it has a bottom reservoir and includes a drain kit as an option under special accessories.
Re: zanussi – bottom reservoir and condensate drain kits
The Zanussi condenser dryers with the water tank at the bottom can be gravity drained away via the capped outlet on the rear.
Alternatively something like a Bosch, that can be plumbed out via a pluimbing out kit is a better option. These are fully pumped, with the plumbing out kit easily available.
