Zanussi built in solid hotplate
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi built in solid hotplate
  • #87901
    rolf
    Hi not sure of the model number for the zanussi built in hob but is changing the hotplates straight forward on a built in hob ie access underneath or does the hob have to come out.
    Thank you in advance.
    #436352
    matrixresonator
    Re: Zanussi built in solid hotplate
    You’ll need to completely remove the hob (pretty straighforward)
    Then depending on model, theres usually screws around the edges and either the top or bottom panel can be removed.
    #436353
    rolf
    Really appreciate your advice. Thank you matrix.
    #436354
    matrixresonator
    No probs 🙂
    #436355
    rolf
    One more. When you remove the hob do you find you have to reseal or will that stay intact. Thanks again.
    #436356
    matrixresonator
    Sometimes it will reseal, otherwise I usually use either some silicone, or you can buy the sealing steps.
