zanussi c/d TC7102W Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › zanussi c/d TC7102W This topic has 2 replies, 3 voices, and was last updated 16 years, 6 months ago by richardable. Viewing 3 posts - 1 through 3 (of 3 total) Author Posts September 23, 2009 at 11:34 am #48800 richardableParticipant this c/d tumbles but no heat. checked filter, condensor, and water tank. checked heater box and t/stats for break…all ok. found the exhaust stat at 12.o’clock but looks like a pig to check/change.. could it be the timer..? thanks richard September 23, 2009 at 12:35 pm #297769 wilfParticipant Re: zanussi c/d TC7102W if its the one I’m thinking of the stat at 12oclock is accessable from inside the door without major strip down. not too bad when you get down to it. wilf September 23, 2009 at 12:36 pm #297770 timdowningParticipant Re: zanussi c/d TC7102W The stat in the front at the 12 o’clock position is normal cause of no heat. Its a bit tight to access but you should be able to manage it. Just remember which way it came out and that you don’t lose the gasket. Author Posts Viewing 3 posts - 1 through 3 (of 3 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
