I wonder if anyone could help with advice and service information on this cooker.
The fault originaly was that the front LH hob woud not operate so they continued to use the other 3 rings. Now when it is switched on it will display 20 in timer which disappears after a couple of seconds. Then L is displayed for each ring. After unlocking the child lock some rings will have a zero and others will have a line. If you can catch one with a zero in it and put a pan on to cook it will work for about 15 seconds then E9 comes up on display. The hob then shuts down but you can still use the oven plus grill. turn the appliance off and on again at the wall and the fun starts again.
any help will be most appricated
Regards
Geoff
