Zanussi condenser compressor dryer
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi condenser compressor dryer
  • #98735
    slyp98
    Hi guys , another one of these baby’s god they’re troublesome, E32 error conductimetric sensor short, board , wiring , drum shorcutted, anyone repair this fault, likely to be the board ? Thanks Kieran
    #473585
    you dont list a model so cant look anything up but you seem to have access to tech
    have you tried the list of possible faults they list ?
    slyp98
    Hi Dave yeah had a look around i can’t see any wiring loose , sensor maybe but it won’t heat on a timed program either 91609737500 cheers
    #473587
    have you check compresor runs in diagnostic mode
    assume you have checked for power to the compressor in case its siezed
    Hollytree_Technical
    I have had a couple of these where the blower motor (mounted in the rear air duct) fan bearings have seized, remember that it won’t “heat” like a traditional dryer so I find that you are better off pulling out the lower filter while it is running to check for airflow and to see if the evaporator is getting cool to the touch.
    Jem
    #473589
    slyp98
    No power to the compressor waited 5 minutes :mad:, blower motor running ok
    #473590
    have you tried diagnostic mode ?
    slyp98
    Yeah , same result Dave
    #473592
    all i can think now is there must be a relay or triac to operate compressor. check for solder joint problems and faulty relay
    dave
