zanussi condenser dryer ZDC5350W
Home Forums Public Support Forums Help And Support Washing Machine Help Forum zanussi condenser dryer ZDC5350W
  • #30291
    maltesenick
    Three year old machine – been working fine till now ( apart from occasional squeaking drum on startup sometimes. ) Now when switched on, programme selected and start button pressed it runs for a few seconds then stops, lights go out and then back on with start button flashing. When this problem first started it would sometimes run if a different programme was selected – sometimes for the full prog and sometimes only part. Now it just aborts when prog started and returns to pre-start state. I had thought it might be a cable break shorting out under applied load on startup but have disconnected appliance from spur, fitted plug, manipulated cable and still the same problem. I’m stuck!!
    #226659
    maltesenick
    Re: zanussi condenser dryer ZDC5350W
    Hi, got it sorted. While looking at a post from VFL07 ( Aug 31 3.53am ) re a Zanussi washer dryer with electrical probs Penguin45 suggested a dry joint as one possibility. In light of my original ( erroneous! ) thoughts about a cable break it made me have a look at the board and ” Bingo” there it was the little devil. All sorted now and wife pleased its working but disappointed she’s not getting a new machine!
    Many thanks Penguin45!!!
