hi guys strange one this when customer turns grill on works fine .. but when turns it off .. it trips electrics ? any ideas am thinking the selector switch ,, but someone says it might be the element ? mmm ,,:rolleyes:
still more likely an element but don’t assume its the grill
scenario is possibly as the switch turns off the neutral disconnects first leaving the neutral side of the element live for enough time to blow the trip
or it could be the lower element that seldom gets used if its a double oven
mmmm difficult one .. as you say .. as you turn it off ,, you have to turn back through the other settings ,,so what do you think it is mate ?wonder if a should tell customer, to try the top oven and see what happens ?
