ZANUSSI COOKER DOES NOT TURN ON AFTER USING 2 PLATES ?? ?NCE
Home Forums Public Support Forums Help And Support Cooker And Oven Forum ZANUSSI COOKER DOES NOT TURN ON AFTER USING 2 PLATES ?? ?NCE
  • #69766
    Todorqgata
    Hi everybody,
    YESTERDAY WE WE’RE COOKING ON THE 2 HOT PLATES (AT ONCE) OF OUR COOKER/OVEN ZANUSSI ZANZCS6642. SUDDENLY IN COUPLE OF MINUTES THE PLATES HAVE STOPPED TO HEAT AT ALL AND AFTER THAT MOMENT COOKER/OVEN JUST DOES NOT TURN ON…
    MAYBE ITS BECAUSE OF USING 2 PLATES SIMULTANEOSLY…
    DOES ANYONE CAN SHARE IDEA WHAT COULD BE THE PROBLEM, PLEASE?
    I CAN UPLOAD PICTURES MAYBE IT WILL HELP
    THANK YOU!
    Todor
    #375892
    One of the hotplates will have caused the consumer board fuse to go or RCD to trip!
    By the way…….Caps Lock OFF please…..no need to shout! 😉 😀
    #375893
    Todorqgata
    Re: ZANUSSI COOKER DOES NOT TURN ON AFTER USING 2 PLATES ??
    Hi thanks for the answer.
    What can I do more to define the exact problem, eventually does it worth to replace these parts or it is too expensive (the oven is from 2004)
    Thank you
    #375894
    They’re cheap enough to take a punt on, all listed here…
    http://shop.ukwhitegoods.co.uk/Cooker+{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} … ements.htm
    Easy enough to replace as well although getting into them can sometimes be a challenge.
    HTH
    Todorqgata
    Hi thank you for the help!
    We found where the problem is:
    There where a short circuit in the power plug which caused a burn of the brown power cable.
