Zanussi Cooker – Top Oven Light Query
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Zanussi Cooker – Top Oven Light Query
  • #103053
    MikeDurk
    [h=2]I recently bought Zanussi gas cooker, ZCG43250WA. The top cavity light only comes on when grilling, but not when used as an oven. I think this must be a fault but Zanussi say it is designed to work this way for energy efficiency reasons!! I think I am being fobbed off, but can anyone out there confirm if the top light should work when the top oven is on? The bottom oven lights up when in use as expected.[/h] Thanks in anticipation.
    #491607
    I can’t find any info on it but, it’d not surprise me if they did that and it’d be a conscious choice to make it work that way.
    have you got the pnc number as there are 10 different ovens with the same model
    As K said it would not suprise but it does seem strange to make the light in the top oven work differently from the lower one
    MikeDurk
    Many thanks for the replies so far. In response to Dave, the Product No is 948905148. Hope this helps find out if the top oven should light up.
    #491610
    there are 2 more digits on the end of that number
    there are still 10 units to choose from
    MikeDurk
    Hi Dave, I have checked the Prod. No. and there are 2 more digits separate from the sequence I gave before. The extra numbers are 09. Hope this helps, and look forward to hearing if this helps you answer my question. Regards, Mike
    #491612
    ok makes sense now in a way
    assume top oven is gas but grill in top oven is electric
    so they strap the light onto the grill element so thats ok
    if they wanted to make the light work on the oven there would have to be a complicated switch just for the lamp.
    if the top oven was electric and not gas it would be easy
    MikeDurk
    Thanks Dave for your thoughts. So it sounds like the top light only works with the electric grill and not the gas oven by design, rather than being a fault. Pretty poor in my opinion, and sounds like a cost saving decision by Zanussi designers rather than the “energy efficiency” reason they gave me. Not a great example of the “appliance of science”, but looks like I am stuck with it. Thanks again for looking into this for me. Regards, Mike
