Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Zanussi cooker ZKC6020w pnc 948522181
- This topic has 1 reply, 2 voices, and was last updated 14 years, 9 months ago by
winker.
June 17, 2011 at 11:56 am #63430
winker
ParticipantWent to this cooker for a trip fault (earth leakage) and found
front left plate (large single circuit) six/seven position switch
had two contacts slightly welded.Teased them apart and mega test was ok.Ordered new switch and fitted,five weeks later it has done it again,switch welded contacts as before.
Just wondering whats going on here and whether this is a recognised fault or factory fault.A solution would be appreciated.Found this post and wondered if it has any bearingregards steve
ovenby chris211 ยป Wed Mar 17, 2010 7:28 am
Service Bulletin
Cooking
Product Group:22
Ref No:CM07005
Subject: ALTERNATIVE MAKE OF SELECTOR SWITCH
Brand: Tricity Bendix, Zanussi, Electrolux, Zanussi-Electrolux
Models:
SE305, SE310, SE323, SE326, CSE327, SE335, SE340,
SE402, SE424, SE428, CSE452, SE452, SB463,
CSE500, SE500/1, SE501, SE501/1, SE505, SE550, CSE551, SE551, SE553, SE558, SE558/1, CSE560,
DDO61CE, EK5361, EKC5044, EKC5045,
ZCE5000, ZCE5001, ZCE5200, ZCE7610
ZKC5030, ZKC5540, ZKC6010, ZKC6020
An alternative make of selector switch (Dreefs) part no. 3890832011 is now available for the models listed above.
This new selector switch has been fitted to all products from serial no. 7170001.
Please note when replacing the original switch with the new alternative switch, the connections remain in the same position with the exception of the white and black wires, which are reversed as shown in the two example illustrations below:
ORIGINAL SWITCH WIRING
REPLACEMENT SWITCH WIRING
Failure to reverse the black and white wire connections will result in the hotplate not regulating correctly.
GBT 06.07 Page 1 of 1.Hope this helps Kaz i cant get the pictures on this part of reply so you can see the way they are supposed to be but it is explained above
chris211
Active Poster
Joined: Wed Nov 16, 2005 10:00 amJune 21, 2011 at 9:32 am #353747electrofix
ModeratorRe: Zanussi cooker ZKC6020w pnc 948522181
what makes me think here is it blew an rcd the switch cant do this (unless it melts) it could blow a mcb (ie short circuit)
think the ring may have an intermittent short
only thing that can weld contacts it very high currenthope it helps
