Hi Guys,
this fridge/freezer is leaking water out of lower freezer compartment. The drain hole is freezing up and preventing defrost water from draining into water tray on compressor. What is the most likely cause? The readings for the two defrost heaters are as follows Armoured heater( Thicker one) is 499ohms and the stylus heater is 542ohms. Have not checked the thermal fuses.
