Zanussi d/w inlet valve wont shut off
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi d/w inlet valve wont shut off
  • #94776
    slyp98
    Hi all , im having this issue where the water fills , then stops for 10 seconds then fills again after 60 seconds the wash mptor kicks in but the inlet valve staus open and keeps filling and wont stop anyone
    PNC 91151611000 ZDF 14011WA
    #458298
    has the pressure switch chamber been modded on this one as its listed as models that are affected ?
    slyp98
    Dunno Dave I doubt it, where’s the chamber, all I can find is the water chamber on the l/h side there’s no switches anywhere to be found does the pcb control the length of time for filling?
    #458300
    whitevanman
    have you changed the water valve ?, I had issue on Boshe washer, no issue with filling when off, but kept filling when water supply voltage stopped.
    #458301
    slyp98
    all ok again chaps installed that service kit Dave , did the trick thanks again
