Zanussi D/W Model ZDI6041 Prod 911841103
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi D/W Model ZDI6041 Prod 911841103
  • #40636
    Alanj
    Hi Guys,
    above dishwasher works ok except that when it is finished it’s program it still has water in the bottom of the tub. The water is clean, pump does work, heater ok. Any Ideas, timer perhaps? 😕
    Alan
    #267088
    Re: Zanussi D/W Model ZDI6041 Prod 911841103
    How long is the drain hose? There’s always going to be some water in the sump, the amount will depend on the length of the drain hose and its path to the sink or standpipe. Maybe an anti-syphon valve spliced into the hose at its highest point might help here. Or it might only be necessary to raise the hose a bit so water can get away.
    Timer sounds like a total shot in the dark!
    Mike.
    #267089
    Minge
    if the water is clean i doubt it will be a syphoning issue. Perhaps an inlet valve bypass???
    #267090
    I don’t mean siphoning, I mean back flow.
    Mike.
    #267091
    It’s a single motor machine; it reverses to drain. I’d pull the motor and check the condition of the impellor stack. The one nearest the motor (I think….) is the drain one – I have been to so many with broken impellor vanes – just doesn’t shift enough water. You can buy the impellor stack as a spare. Be careful, the plastic drive shaft is not a spare.
    Alanj
    Hi Guys,
    looks like a valve problem. Customer phoned to say water was coming out of dishwasher but she hadn’t used it since I was there.
    Thanks for the replies. 😀
    Alan
    #267093
    Minge
    welcome buddy.
