Zanussi D/W no heat
  • #65223
    ZDT 6053..Pnc 911939202-02
    Element OK, pressure switch operating correctly, all wiring appears sound.
    Had a look at the PCB but it shows none of the usual signs of burnt solder joints.
    A quick look at the wiring diagram, can’t see anything else obviously in line.
    Before I order a new PCB is there anything else that I am missing.
    TIA.
    scots
    Re: Zanussi D/W no heat
    Had the same problem with a Zanussi last week, cant remember exact model. After doing all the same tests you have done I bit the bullet and ordered the PCB and just in case also the NTC.
    Result phew!!
    Good luck with yours
    Brian
    #359731
    The machine belongs to a very good friend which can often be more of a problem in cases like these.
    I will have to run the cost of a PCB by them to see how it goes, I can always blame you if it goes t**s up. 😀
    Seamy
    Think its normally relay trouble on the P.C.B, if you’re handy with a soldering iron you could take board away & get a relay to suit.
    #359733
    Always play safe with Zanussi D/W PCB’s myself.
    I have seen one or two badly fire damaged, don’t want to take that chance.
    #359734
    scots
    But just imagine the relief when/if it works!!:)
    #359735
    keithwilliams
    pcb doesnt have to be burnt to stop working. did zanussi couple of weeks ago. get a very good look at relay contacts these seamed ok but were infact cracked around joint. resoldered and away she went with original relay.
    #359736
    If it’s an older machine it’s worth replacing the relay as the contacts will probably be burnt. On newer machines (2/3 years) the solder joints are probably all that needs doing. Same with washing machine heater relays.
    Mike.
