PNC 91151619003
This dishwasher was described as just stopping and not draining.
Reset program and it drains. Put it on quick wash 30 minutes and it drained, filled, washed, released tablet, heated.
But it washed continuously for 30 minutes, then just stopped and turned itself off, full of water and did no rinse or anything. Just filled and heated and washed for 30 minutes then ended.
Any thoughts?
Don’t think that’s the issue. This model has an ‘auto turn off’ or something like that, where when the program ends it turns itself off. It ended a 30 minute program at 30 minutes but just turned off with no drain.
so from that i conclude you can turn it back on instantly, you dont have to wait or turn it off at the socket etc
had a similar fault on a bosch washer. started programme and mine turned off after 20 mins but you could not immediatly turn it back on. changed the power supply chip on the board and all is ok now
