Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Zanussi DA6142 drain doesn’t go. Help!
- This topic has 7 replies, 2 voices, and was last updated 16 years, 10 months ago by
benten.
May 23, 2009 at 12:04 am #45933
benten
ParticipantHave already checked no blockage at all.
checked the waste connection. it seems not even a single bit of wet, which means no discharge from the machine.
The machine not even stop after wash. humming noise can be heard.
Any solution! Help! Thanks
May 23, 2009 at 12:28 am #287687Penguin45
ParticipantRe: Zanussi DA6142 drain doesn’t go. Help!
Drain pump blocked or failed? It’s accessible through the lower front cover plate.
Bail out as much water as you can before removing it. There is a locking tab to release, then the pump should pull away for inspection.
Power off first.
May 23, 2009 at 4:34 pm #287688benten
Thanks Penguin45.
Have opened up the dishwasher and found the pump. But don’t know where the locking tab and can’t take out the pump.
Any Tips!
Cheers
May 23, 2009 at 5:39 pm #287689Penguin45
Have a look at THIS PICTURE. Centre part of the tongue is the lock.
May 24, 2009 at 12:49 am #287690benten
Thanks again.
Already got it. nothing inside. Probably pump failed. Will test it n see.
Many thanks
May 24, 2009 at 4:23 pm #287691benten
Penguin45,
checked the pump. it works well
put it back the machine and gave separte power cables to it. Pour water in the machine. pump goes well with the external power.
Then put back the machine power cables, tried the machine again. drain doesn’t go again. looks like the machine cannot tell the pump to work.
Any more help!
May 24, 2009 at 8:27 pm #287692Penguin45
Continuity test back to timer unit is your next step. Possible that the loom has broken at the door pivot point. If you do have continuity, switching problem in the timer is the culprit.
May 25, 2009 at 6:40 pm #287693benten
Thanks Penguin45.
I guess that may be the case. What can I do now? How can I sort this out?
Any advice? Thanks!
