Zanussi DCE 5655 keeps pumping even when I open the door
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Zanussi DCE 5655 keeps pumping even when I open the door
  • #89653
    Capricious
    My Zanussi DCE 5655 dishwasher started continually pumping. It continues pumping even when I press the on/off button (the light goes out but the pump continues). The pump continues even when I open the door. Switching off at the plug is the only thing that stops it.
    All the program button lights in the door have gone out and are unresponsive – they seem to be jammed.
    I have cleaned all the filters and taken out what I can to clean in the interior, and cleaned where the waste pipe connects to under my sink – to see if there was anything blocking.
    Is this a problem with the door panel, or an indication that I may have water leaking into the bottom tray?
    #442036
    Re: Zanussi DCE 5655 keeps pumping even when I open the door
    Water leaked onto base and flood protection device activated.
    #442037
    Capricious
    model number : DCE 5655
    Product number: 911338008/61
    Serial number: 45257-407
    #442038
    Capricious
    Have you any advice how I get to the bottom panel with this model? Being a small countertop model there is no kick panel.
    #442039
    Capricious wrote:Have you any advice how I get to the bottom panel with this model?
    With the power disconnected, firstly the side panels need unscrewing from the front and unclipping from the back. Then lay the appliance on its back and remove the bottom plate. Access all areas from there. 🙂
    #442040
    Capricious
    Great Martin, thanks. I’d got as far as removing the side/top panels but stumped where to go next. Turning it upside down is my next move. Cheers.
    #442041
    NO! Not upside down! On its back!!!!
    #442042
    Capricious
    With the water gone from the base the dishwasher is working normally again. Thank you!! 😀
    Gotcha Martin – Sorry, I did mean to turn it on its back, not upside down. :eeek:
    There was water in the base which I mopped up. I couldn’t see where any leak was coming from. I have cleaned any old residues I could see. Do you recommend a few cleaning cycles with Bicarb or vinegar?
    I know table-top dishwashers don’t suit everyone, but I love my litle Zanussi that is perfect for one person, and better than hand washing especially as I don’t have hot running water much of the time. I find it is more efficient than my posh, slim-line Bosch.
    If it happens again soon I will have to look further into how water is leaking into the base. Do you have any advice what to look for?
    Many thanks! :tup:
    #442043
    MaxwellD
    Look for water drips? 🙂
    Leaks are sometimes difficult to pinpoint, your best bet is to let it wash on the highest temperature, and then just sit with it until you see water dripping down.
