Zanussi DCE5655 not draining
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Zanussi DCE5655 not draining
  • #86953
    nitch
    Hello,
    I’ve read through other posts but can’t seem to figure out the problem with my table top Zanussi DCE 5655 dishwasher.
    It’s not draining anymore. If I drain the machine, it will run again but after it’s gone through the wash cycle, it tries to drain but doesn’t succeed properly. The waste pipe does feel warm through the machine and out to the drain but there can’t be much water making it through.
    I have a feeling it may be the pump as it seems noisier than I remember but I have got the cover off which will obviously make it louder.
    I’ve cleaned out all the obvious parts but I haven’t gone so far to take it apart further other than removing the cover at this point.
    I took this video in case it helps.
    YouTube Video
    The flashing lights are the programme selected and the middle of the cycle lights.
    Let me know if you need any further information. Many thanks
    #433501
    Re: Zanussi DCE5655 not draining
    you need to find and take the drain pump apart. most likely a peice of glass or the like
    nitch
    Ok thanks. That’s a project for tonight.
    Cheers
