Zanussi DCS 12 W tabletop dishwasher
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Zanussi DCS 12 W tabletop dishwasher
  • #52952
    Camel
    I have had this appliance for around 4 years now and only had one problem (detergant in a pot i was washing) it got stuck on drain and after tipping it (reset) it worked no worries.
    Today I went to use it as normal, It starts up fine lights all ok and blade is spinning inside, after a few minutes it moves onto constant drain and the lights on the front go out. If I tip to reset it goes along again for a few minutes more then jumps to constant drain. I checked the water and it is freezing.
    Is there mayube a blockage (but water empties no problem) is it the element??
    Im Hoping someone here could point me in the right direction.
    Thankyou in advance
    camel.
    #313822
    TheSpinDoctor
    Re: Zanussi DCS 12 W tabletop dishwasher
    Hi.
    The anti flood device has triggered because you have a leak.
    #313823
    Camel
    TheSpinDoctor wrote:Hi.
    is that game over or is it possible to repair it?
    #313824
    Lots of places these little blighters can leak from. Worth getting the base panel off and setting it up on a couple of blocks and seeing where the water is coming from.
    Power off for anything other than observation.
    Camel
    Penguin45 wrote:Lots of places these little blighters can leak from. Worth getting the base panel off and setting it up on a couple of blocks and seeing where the water is coming from.
    gonna strip it out and see whats what tonight, see when you say it is leaking, are we talking about a leak, from the main vessel into the electronic side of things?
    thanks guys
    #313826
    TheSpinDoctor
    thanks guys
    All that happens is the water pools in the base, raises the polystyrene float, switches microswitch, supplies permanent feed to drain pump.
    Not neccessarily leaking onto electronics. Could be a loose hose clip or softener nut. Could be a split in something. Could be blocked air chamber causing overfill. Investigation will be required.
